Automate new Malwarebytes UI
LuisMiguel
Post by LuisMiguel »
Hello, Malwarebytes has changed the UI, I am not able to automate it, any help would be appreciated.
Regards.
Re: Automate new Malwarebytes UI
Hi Luis Miguel.
I know. I'm fixing the automation in the system repair section, and then I will update the MBAM's script in the script collection.
That one was easy. It just needed a little adjustment in the second click's position.
Check out the new script.
http://www.carifred.com/uvkscriptcollec ... can_en.php
I was wondering, since you want to run several scans asyncronously, this topic gave me an idea.
You can actually run the builtin scans asycronously if you create an external script for each command.
Take this example:
Place all the scripts in the same directory as you have UVKPortable.exe. Can be a USB stick, so you can move it to the client's computer.
Script 1: MBAM.uvk
 <MBAMScan>
Script 2: SAS.uvk
 <SASScan>
Script 3: TDSSKiller.uvk
 <TDSSKillerScan>
Main script: Scans.uvk
 <Run>
UVK_en.exe -ReadFile "%InstallSourceDir%\MBAM.uvk" -Auto
->Sleep(10000)
UVK_en.exe -ReadFile "%InstallSourceDir%\SAS.uvk" -Auto
->Sleep(10000)
UVK_en.exe -ReadFile "%InstallSourceDir%\TDSSKiller.uvk" -Auto
Then, just drag the Scans.uvk script over UVKPortable.exe, and you have asyncronous scans with 10 seconds interval.
LuisMiguel
I will test it
Thank you
LuisMiguel
Hello, for some reason doesnt work, I tried it on a clean windows 7 32b and 64b, the log:
"2015/03/24 12:10:04 Running UVK_en.exe -ReadFile "%InstallSourceDir%\SCRIPTS\MBAM.uvk" -Auto...
UVK_en.exe -ReadFile "C:\Users\YO\Desktop\tools\UVK\SCRIPTS\MBAM.uvk" -Auto was successfully started."
but dont do nothing
Sorry, I forgot to tell you that for MBAM to work you will need to use the latest beta. See the change log of the beta page for more info. The MBAM's automation is not working properly even in that beta, but I intend to upload a new stable version today.
http://www.carifred.com/uvk/beta
LuisMiguel
With the beta version the external scripts (mbam.uvk) are called correctly, I will wait for the next beta version.
Regards.
LuisMiguel
Fred wrote: I was wondering, since you want to run several scans asyncronously, this topic gave me an idea.
Take this example:
Script 1: MBAM.uvk
 <MBAMScan>
Script 2: SAS.uvk
 <SASScan>
 <TDSSKillerScan>
 <Run>
->Sleep(10000)
->Sleep(10000)
Hi Fred, I have some time to try this, is exactly what I want, but isnt working fine, UVK popup with the unistall popup and some scripts doesnt work, can you teset this on latest version?
Regards.
Hi Luis Miguel.
I will test it out later on today and let you know the news.
