Run script for Ultra adware
pcrolin
Post by pcrolin »
Hi There,
I can start a script for launching superantispy by:
<UVKCommandsScript>
<SASScan>
How can i start Ultra Adware Killer, the same way?
Very nice tool by the way :-)
Re: Run script for Ultra adware
Hi pcrolin.
I didn't add support for running Ultra Adware Killer through scripts.
But you can easily create your own script that downloads and runs UAK.
I'm going to finish some things I'm working on, and then I'll post a script for you.
pcrolin
Post by pcrolin »
All Right. thx in advance
Ok here is the script. Sorry for the delay.
The script updates Ultra Adware Killer with the latest version of the tool, starts the scan and waits until UAK is closed. The script also automatically uses the 64 or 32 bits version of the tool, according to the current OS arch.
<UVKCommandsScript>
;Download the Ultra Adware killer version corresponding to the current OS arch
 <UpdateSoftware> -x64
%ThirdParty%\UAK64.exe | http://www.carifred.com/ultra_adware_killer/UltraAdwareKiller64.exe
 <UpdateSoftware> -x86
%ThirdParty%\UAK32.exe | http://www.carifred.com/ultra_adware_killer/UltraAdwareKiller.exe
;64 bits automation (Run and start scan)
 <Run> -x64
%ThirdParty%\UAK64.exe /NoUpdate
->WaitWindow()
->WaitControl([CLASS:Static; INSTANCE:11])
->ClickControl([CLASS:Static; INSTANCE:11])
->WaitProcessClose()
;32 bits automation (Run and start scan)
 <Run> -x86
%ThirdParty%\UAK32.exe /NoUpdate
->WaitWindow()
UAK automation.uvk
(773 Bytes) Downloaded 262 times
Enjoy!
pcrolin
Post by pcrolin »
Thank you verry much. Super!
pcrolin
Post by pcrolin »
Hi there,
I have one more question, i put this file in a folder (rolinrepair) that i place 0n C:\ directory.
Than i open a script and one of de commands i put in with is:
<RUN>
c:\ROLINREPAIR\UAK automation.uvk
but it won't start. I cant figure out what im doing wrong.
* Tried replacing underscores (rolin_repair changed to rolinrepair)
* tried removing spacebars UAK automation to UAKautomation
* tried running it from the desktop (Rolin_repair placed on desktop) with command: %Desktop%\ROLIN_REPAIR\UAK automation.uvk
* tried running it from the desktop (Rolin_repair placed on desktop) with command: %USERPROFILE%\Desktop\ROLIN_REPAIR\UAK automation.uvk
Whole script looks like this:
<UVKCommandsScript>
<Run>
msconfig
%windir%\system32\wuapp.exe
C:\Program Files\Internet Explorer\iexplore.exe http://www.pcrolin.nl/downloads/PCRolin-Helpdesk.exe
<Comment>
Programma's verwijderen vanuit configuratiescherm
<cmdscript>
appwiz.cpl
<Comment>
HITMANPRO
The commands below will download Hitman pro.
They will automatically download the correct file, depending on the Windows architecture.
%ThirdParty%\HTMNPro.exe | http://dl.surfright.nl/HitmanPro.exe
%ThirdParty%\HTMNPro.exe | http://dl.surfright.nl/HitmanPro_x64.exe
<Comment>
The command below will start the scan.
Delete " /quick" (without the quotes) to run a full scan.
Delete " /noupload" to enable upload files.
<Run>
%ThirdParty%\HTMNPro.exe /scan /quick /noupload
;Because sometimes HitmanPro performs an update, which restarts the process,
;we wait 30 seconds and then try to catch its window based in its title and class.
->Sleep(30000)
->WaitWindow(10,[TITLE:HitmanPro; CLASS:CoreForms20.Control])
<UVKCommandsScript>
%ThirdParty%\UAK64.exe | http://www.carifred.com/ultra_adware_ki ... ller64.exe
%ThirdParty%\UAK32.exe | http://www.carifred.com/ultra_adware_ki ... Killer.exe
<Run> -x64
->WaitWindow()
<Run> -x86
->WaitWindow()
<RUN>
c:\ROLINREPAIR\2SAS.uvk
c:\ROLINREPAIR\3Mbam
c:\ROLIN_REPAIR\4_TDSKill
c:\ROLINREPAIR\INSTALLS\SystemNinja\PCRolincleanup.exe
<Comment>
Nu gaan we de rest updaten
<FixBrowserShortcuts>
<CleanAllUsersTemp>
<CleanupRegistry>
<CleanupJunkFiles>
<UpdateFlash>
<UpdateDirectX>
c:\ROLINREPAIR\UAK automation.uvk is not a valid command for <Run>.
<Run> can not be used to open files, it can only be used to run commands. You need to specify the whole command, like this:
  <Run>
%UVKExe% -ReadFile "c:\ROLINREPAIR\UAK automation.uvk" -Auto
%UVKExe% -ReadFile "c:\ROLINREPAIR\2SAS.uvk" -Auto
http://www.carifred.com/uvk/help/cmdswitches.php
Don't know what these are:
Are they files? folders?
Also don't know why you want to run UAK automation.uvk since the UAK automation is already part of the main script.
pcrolin
Post by pcrolin »
Hi There,
Ok that explains a lot.
3mbam for example is a uvk file within :
<UVKCommandsScript>
<MBAMScan>
I do this so i can run the programms simultanious. otherwise i have to wait till a program is finished, andclose it
to go to the next one.
pcrolin
Post by pcrolin »
I just tested it and it works! Only without the -auto parameter. Script log says it was started bud it didn't. Without de -auto UVK starts and i have to manualy klick on "Run/Fix listed".
It would be super if i didn't have to klick on that button, but if it would automaticly starts.
Is that possible?
I used this in my script:
<RUN>
%UVKExe% -ReadFile "%Desktop%\ROLINREPAIR\INSTALLS\mbam.uvk"
%UVKExe% -ReadFile "%Desktop%\ROLINREPAIR\INSTALLS\sas.uvk"
%UVKExe% -ReadFile "%Desktop%\ROLINREPAIR\INSTALLS\tdskill.uvk"
%UVKExe% -ReadFile "%Desktop%\ROLINREPAIR\INSTALLS\UAK automation.uvk"
%UVKExe% -ReadFile "%Desktop%\ROLINREPAIR\INSTALLS\systemninja\PCRolincleanup.exe"
Hi pcrolin.
I found out that is a bug in the version 7.0.0.1. UVK is not running the script if you use the -Auto switch.
I uploaded a new beta version 7.0.0.2. Use that version instead, and the -Auto switch should now work fine.
Sorry about that, and thanks for helping me to find the bug. I'll just try to spot some more bugs, and then I'll make this beta stable.
pcrolin
Post by pcrolin »
Hello there,
7.0.0.2 works like a charm. Thx.
And there i am with a new question :-)
Is there also a script to run systembooster on de same way as UAK.uvk?
LOL I'm sitting on the edge of my seat waiting for an answer to:
Are you going to tell us?
@Brink
I think those were UVK scripts, but he forgot to enter the file extension.
@pcrolin
For the System booster, you have the <CleanupRegistry> and <CleanupJunkFiles> commands.
