For some reason almost every Windows 7 box I immunize it will uncheck the Hosts file but if I check it manually after it has unchecked it it will stay then.
Is there something to this or do I need to investigate father as a bug for you?
I should also mention that I just select "recommended" and then apply when it does this.
System Immunization - Host File
Re: System Immunization - Host File
Hi Jim, I've run across that issue a few times too. It's like if, the first time, UVK is only able to change some of the ACL entries, and the second time it manages to set the rest of them. I will make UVK try the immunization operation twice, that should fix it.
