Rogue killer
Rogue killer
I have tried your built in Rogue Killer a few times and most of the time it errors out. I then turn around and run the Rogue Killer script I posted here and it works fine. Is there a way I can get debug info out of UVK? I would really like to give you more info than "It don't work" but it does not tell me anything about why it didn't work.
Re: Rogue killer
Probably the 32 bit version is not so 64 bit compatible. I'll make UVK download as you have in your script.
Thanks for reporting.
Re: Rogue killer
The 32bit version will work on 64bit but it won't load the kernel driver for rootkit detection. As far as I know that's the only reason you have to the right version.
