Hitman Pro and Rogue Killer
Both of these apps have separate EXEs for x86 and X64 so as far as I can tell the standard "System repair" script does not correctly work for them.
For those that are interested I am posting scripts to download and run these depending on OS version. I am also including my main settings file so that you can see how to run the scripts from system repair.
Rogue Killer:
<UVKCOmmandsScript>
<UpdateSoftware> -x86
%InstallSourceDir%\Third Party\RK\RogueKiller.exe | http://www.adlice.com/softs/roguekiller/RogueKiller.exe
<UpdateSoftware> -x64
%InstallSourceDir%\Third Party\RK\RogueKillerx64.exe | http://www.adlice.com/softs/roguekiller/RogueKillerX64.exe
<RunWait> -x86
%InstallSourceDir%\Third Party\RK\RogueKiller.exe -autoaccepteula -autoscan
<RunWait> -x64
%InstallSourceDir%\Third Party\RK\RogueKillerx64.exe -autoaccepteula -autoscan
HitMan Pro:
<UVKCOmmandsScript>
%InstallSourceDir%\Third Party\HitMan\HitManPro.exe | http://dl.surfright.nl/HitmanPro.exe
%InstallSourceDir%\Third Party\HitMan\HitManPro_x64.exe | http://dl.surfright.nl/HitmanPro_x64.exe
<RunWait> -x86
%InstallSourceDir%\Third Party\HitMan\HitManPro.exe /fb /scan /nocookies
<RunWait> -x64
%InstallSourceDir%\Third Party\HitMan\HitManPro_x64.exe /fb /scan /nocookies
HitMan Pro No update (Possibly good for no Inet, otherwise Hitman Pro is useless when you need it most):
<UVKCOmmandsScript>
<RunWait> -x86
%InstallSourceDir%\Third Party\HitMan\HitManPro.exe /fb /clean
<RunWait> -x64
%InstallSourceDir%\Third Party\HitMan\HitManPro_x64.exe /fb /clean
The settings file assumes you use "Third Party" for the directory in your UVK launch location, for example the way you store it on your thumb drive.
SR settings.uvksr
Example settings file
(11.55 KiB) Downloaded 1266 times
HitManProNoNet.uvk
Hitman Pro possibly no Inet
(427 Bytes) Downloaded 1279 times
HitManPro.uvk
Hitman Pro Script
(447 Bytes) Downloaded 1163 times
RogueKiller.uvk
RogueKiller script
(484 Bytes) Downloaded 1207 times
Re: Hitman Pro and Rogue Killer
Jim, I'm really glad you got into scripting.
Keep up the good work!
Thanks Fred....
Just trying to help out the community. I hope that people find something I have done or posted useful.
Old thread but if you've got the licensed version of Rogue Killer, you will have a file "RKUpdater" which downloads the latest version and then launches it. The downside is that it does not currently support passing on parameters but I've just emailed with them and they like the idea so it may be coming sooner rather than later.
I have thought about the paid version but have not really had time to see what I "get for my dollar" over the free version.
I wish Hitman Pro had a reasonable paid version but their prices are just crazy in my opinion...
stv_thms
Post by stv_thms »
Cool, adding now 8-)
