System repair issue since 6.8
Vicelord
Post by Vicelord »
While using the system repair section it seems that UVK suddenly stops recognizing when processes end so the screen that waits for the process to end keeps waiting.
example : the screen "Installing Java (x86)" will never end and the wheel keeps spinning. Doesn't seem to be related to any specific process. But whenever this bug starts to pop up it never leaves, even after a reboot you need to manually press cancel on the screens. I've had this bug on nearly every pc since 6.8.
Removing and reinstalling UVK doesn't help either, and the trouble is certain screens do not have a cancel button so you need to reboot your pc since you can't end the process of uvk in process explorer. (always access denied).
Updating to the newest beta didn't help unfortunatly
Re: System repair issue since 6.8
Hi Vicelord. Bill already reported this bug.
viewtopic.php?f=4&t=857
Unfortunatelly, I tested on windows 8.1 and Windows 7 and it worked fine for me. The issue seems to only happen on some systems. I'll be counting on you guys to help me to fix it, since I can not reproduce it.
I'm gonna make some more checks in the process monitoring function and upload a new beta. I'll let you know when it's released.
Thanks for your help.
Vicelord
Post by Vicelord »
sorry didn't notice bill posted it. I'll try to figure out what's going wrong
