I been doing some thinking and I think I have a decent Idea here. This is not particularly a feature request I'm just looking for feed back on the idea.
In UVK you can add tools and such to the maintenance section and that is great! It's getting better all the time due to Fred's hard work. But, I think I think it would be cool to have a stand alone app that you can catalog all your tools in. For instance, if you need a password utility you just select it from a list and it gives you a button for each tool you have with you having to go through folders. Same thing for system info tools. Maybe you have couple defraggers. I use a couple different automated installers so one could even have a list for that.
I don't know, what do y'all think? It seems like a good idea.
Just an idea....
Just an idea....
Re: Just an idea....
Hi Jim,
So you’re saying (for instance) that there should be an antivirus button and when you click on it all your antivirus programs would show up and be selectable from there? That’s not a bad idea. It would shorten the initial lists.
Think it's possible this last one is a spammer.
Thanks, Jim.
Both 2 last posts in this topic were spam. I deleted the users and posts.
I was thinking they both were but wasn't 100% on the first one... knew the second one was
