Uncheck boxes after fixes
Is it possible to have UVK automatically uncheck fixes after they have run or when all fixes have completed?
PS: Happy New Year! :D
Re: Uncheck boxes after fixes
Hi Bill. Happy new year for you too!
You have a right click context menu, in the Fixes/Apps list. One of the options is "Uncheck all".
If you think that option is not enough I can add a "Uncheck fixes after running" check box at the bottom of the window.
Sorry for the delay. I’ve been sicker than crap lately. I’m coming around now though.
Anyway, I do know the option to uncheck all is there. The trouble is I always forget to uncheck things and then check more stuff and hit go before I realize I’ve been a fool. If it’s not too much trouble to add an uncheck fixes after running that would be great! I know I still need to actually check the box but, I think I will be more likely to remember to check the box as I’m checking things than after time has passed while the fixes are running. :roll:
Hi Bill.
As a better thought, I think it is logical to automatically uncheck the fixes/apps after they are executed.
I will make UVK automatically uncheck the them and release a new beta with that option updated today.
Thanks for posting this good idea.
Thank you Fred. :D
