win 7 security 2012 firewall alert fake anti virus help
jcane1
Post by jcane1 »
ok how do I use UVK to kill this one?
Re: win 7 security 2012 firewall alert fake anti virus help
Hi jcane1.
I moved the topic to the Malware removal help section. Does the rogue let you run UVK in normal mode?
jcane1
Post by jcane1 »
we first ran malware bytes and removed a bunch of root kits, now we are running uvk, in normal mode and it used malwarebytes, now superantispyware, and then one more program , it has already found : wow that was fast
now it is running hitman pro
it removes a bunch of stuff
After the scans are finished, you may want to create a UVK log, zip it and host it in the next reply as attachment.
I'll have a look at it to make sure no infections are left, if you want.
All the best,
