Just a quick question. I am looking to change my computer so the WAU Manager does my updates instead of the Windows Updates program. That one just seems to suck lately. Is there a way to tell it to run on a regular basis, but silently?
WAU Manager
Re: WAU Manager
Hi Fred. Yes, everything is on WAU Manager's Dashboard. UI mode: Quiet. Then use the provided schedule to have it updating whenever you want.
Re: WAU Manager
Thanks Fred, I appreciate it. I'm trying to learn Powershell, so I wonder if there is a way to script this all through there. I'll have to play around with it. Otherwise I'll just set it up with the UI.
Re: WAU Manager
Oh, I see. That is perfectly doable. You see, Wau manager creates a scheduled task and specifies a /flag= argument that defines how the application should behave.
For example, the following command will make WAU Manager update drivers and software every 10 days, and do not show any UI:
Possible flag values are:
1 for updating drivers
2 for updating software
3 for updating both
8 for progress only
16 for silent (no UI)
so /flag=19 means update both drivers and software silently, no UI.
If you copy/paste the command above, do not forget to update the path of the application.
schtasks /create /TN "WAU Manager Windows Updates Task" /SC DAILY /MO 10 /RL HIGHEST /TR "C:\ProgramData\UVK\WAU Manager.exe /update /flag=19" /F
3 for updating both
8 for progress only
