UVKSR files
Fredclaus
UVKSR files
Post by Fredclaus »
I think that's what they are called. I created a process of tasks I want UVK to run, then I saved the settings as a .uvksr file. When I double click on that file to run it, all it does is open UVK with those settings blocked. How do I get it to execute those tasks when I click on it? Also, is it possible to get it to do this silently?
When I have a .uvksr file, do I need the UVK software to run this file, or can I put just this file on a flash drive, stick it into a computer and run just those tasks?
Re: UVKSR files
Hi Fred. In System Repair, right-click the fixes list (or click the menu button). See at the end of the menu, you have an option to create an automated schedule. I think that is exactly what you need.
FredJClaus
Re: UVKSR files
Post by FredJClaus »
Thanks. That looks like what I'm looking for.
FredJClaus
Re: UVKSR files
One more thing Fred, I'm sure it something I'm doing wrong. I've tested this many times on my machine and it doesn't work. I have the box checked in the UVKSR file to email me a report. However when it finished, I never get the report in my email. I have the option checked in the Reporting section with the correct email address. What did I forget to set up that is causing the email not to come through?
Re: UVKSR files
Hi Fred.
I just tested the Send reports by Email or FTP feature from the System repair module and it worked fine. Are you able to send the reports from the Reporting module instead?
