All in one portable
Fredclaus
All in one portable
Post by Fredclaus »
I'd love to see a way to contain the current three files into one exe file. This way when I'm working on a remote computer I can just send one file instead of three
Re: All in one portable
Hi Fred. Which are the three files you're talking about?
Fredclaus
Post by Fredclaus »
I have a folder that has the Key, Logo, and the executable.
Use WinRar to create an SFX file with them in it, and then set it to launch the exe upon unpacking.
Or you can use UVK's SFX creator, also?
LOL true. I always forget that's in there.
Fredclaus
Post by Fredclaus »
That's a cool idea. I didn't know you could do that. I always do a zip file then unzip it, then run it manually.
