Hello
i interested about Quick Any2Ico command-line ability. but i wanna create a shortcut in context menu to convert right-clicked PNG file(or selected files) to .ico in specified folder.
so i did some registry tweak:
method 1:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\PhotoViewer.FileAssoc.Png\shell\Convert To ico 64\command]
@="D:\\Downloads\\Programs\\#desktop\\#icons\\Quick_Any2Ico\\Quick_Any2Ico.exe -img=1% -icon=D:\\1.ico -formats=64,256 -pngc"
@=""D:\\Downloads\\Programs\\#desktop\\#icons\\Quick_Any2Ico\\Quick_Any2Ico.exe" "1%" "-icon=D:\\1.ico" -formats=64,256 -pngc"
note: becuase WindowsPhotoViewer is registered as defualt programs for openning photos in my OS(win 10), the only way for creating a context-menu for PNG files is "HKEY_CLASSES_ROOT\PhotoViewer.FileAssoc.Png\shell"
i fixed it. the problem was 1%. its wrong. the true one is %1. lol im stupid
also method 2 didnt work with %1 so i just stick to method 1.
but still one thing remain. i wanna it also rename the created file to same name of source file.any idea?
thanks
Hi amymor. Glad you nailed it. I just saw your post and I think you had an excellent idea. I will soon integrate that feature into Quick Any2Ico itself.
Fred wrote: Sat May 02, 2020 8:07 am
Hi again @Fred
I found a very little bug when i used GUI app(also found it when used command line).
The pngs converted to half sized icon also moved slightly to the left. for example i have a png with 128x128 size then converted it to icon with 64x64 size then i resized the png file to 64x64 too with PaintDotNet(for comparing purpose) and finaly when compared two image i found the icon one moved slightly to left. doesn't matter which options(center, crop, stretch, png compression) i choose, it happens every time:
I tried many programs for converting pngs to icons and Quick Any2Ico was the best program i found. because created icons have greater quality than other icons created with other programs(like imagemagic, X2ico, Ultimate icon converter and etc).only the icons created with PaintDotNet and dihav-Png2Ico have same quality but both of them dosnt have any command-line. anyway this very little bug bothers me a little. so i would be happy if it resolves in the future.
I downloaded images 2 and 3 from your last post and opened them with an image editing software called Photofiltre Studio X. Zoomed both to 500% and the result is in the picture below. I do not see any difference in the size or placement. My guess is that the software you use to view icon files automatically clips out the transparent area surrounding your image. That would explain why your image seemed clipped in the left side.
i guess you didnt compare them properly. even in your screenshot the 2th image moved very very slighty to the left .in your screenshot the distance between 1th image and the left side is 3 pixels while it is 2.5 pixels in 2th image.If you want to see it better, you have to switch between the two images no side by side. i did it with PaintDotNet and WindowsPhotoViewer. if Photofiltre Studio X supports tabbed-view maybe you can do it and see what i mean. as i said, i tried many software for converting so if there was something wrong with the photo editor, i had to see it in other created icons too.
thank you for your reply
