Hi there,
Is there an option to changed the default Report Title. It seems to default to my old company name. The report path uses the new company name ok.
Rename Default Report Title
- uvk report title.png (98.03 KiB) Viewed 22963 times
Re: Rename Default Report Title
Hello.
The default report title comes from UVKSettings.ini. In order to change it, you need to update the ini file from which it is retrieved from. The INI file may be remote (cloud synced), or local, in the same place as the UVK package used to install the application.
Otherwise press the Save to file button, and save to the location where you have your UVK package.
Let me know whether that worked.
- Launch UVK and go to the System Repair module.
- Tick the Create professional report checkbox to bring up the Professional report settings dialog box.
- Edit the report title, making it the desired default and press OK,
- Press the Home button, and then go to the Options module.
perfect reply thanks.. all working. Much appreciated.
You're welcome. Glad I could help.
