Hi all,
i have a Sony CyberShot DSC-690 camera and a 128 Gb micro SD card,
impossible to takes video/pictures with 128 Gb micro sd on camera, because "database error" on screen of my camera,
and now the pre_scan log below:
database error on 128 Gb micro SD card on camera
- Pre_Scan_03_06_2019_18_25_08.txt
- (23.96 KiB) Downloaded 2930 times
Re: database error on 128 Gb micro SD card on camera
Try take the memory card out of the camera and temporarily move the Lock tab to the Lock position, then move it back to the Unlock position. Check if there is anything wrong with the memory card. Turn off the camera, remove and insert the memory card several times, then turn on the camera to see if the issue is resolved.
I hope, I help you
regards employee internet monitor at the workplace
I hope, I help you
