Network repair UVKSR file
Hello again everyone.
As promised in my previous post, I'm sharing some of the UVK scripts I regularly use in my repairs. This time I'm posting a script I run in machines that have network / internet connection issues. This script does not create a system restore point because it was already created in my autoload script.
What this script does:
Enable Windows Installer in Safe Mode and then Reboot in safe mode and continue. This allows us to perform the repair operation in safe mode with networking making it easier to remove any malware hijacking the network connection, while still being able to install software/drivers if needed.
In safe mode it will first run an Ultra Adware KIller scan to detect and remove possible DNS hijacks and other eventual malware.
Next it will perform some network related reset operations: Reset IE and internet settings, Reset the hosts file and DNS, Reset IP, Winsock and proxy, Reset Windows services' start types and Fix this PC not visible in the network.
Once all done, the computer is rebooted into normal boot mode. If the issue is not fixed I usually uninstall the LAN/WIFI card's driver and then reinstall it it, or try a plugging in and using a USB WIFI card.
Enjoy!!!
netRepair.uvksr
(8.79 KiB) Downloaded 2024 times
Muhammad Tasneem
Re: Network repair UVKSR file
Post by Muhammad Tasneem »
Thanks a lot Fred, you are A life saver. 👏👏👏
Muhammad Tasneem
Is it possible to make backup the host file before resetting it?
As my experience sometime client used the host file to stop home calling feature of different software.
theGuignol
Post by theGuignol »
Yes thank you Fred!
