Good Morrow peeps
You want to tell us a little bit more about yourself? Post here!
Essexboy
Good Morrow peeps
Post by Essexboy »
Hi there, I heard about this small programme on the Avast forum so I thought I would download it and give it a whirl
I am an instructor at Geeks to Go malware school and I am always on the lookout for new tools to play with :)
Are there any limitations on how or where this tool can be used ?
For example when I am removing malware on line would you rather I linked to your main page or to the download link ?
Can I use it on online malware removal forums ?
A bit about me Hmmm lets see
I use the same name on all forums, I teach at Geeks to go and Whatthetech malware schools.
I do malware removal at the above forums plus Avast, and graduated about 7 years ago as a malware removal person
Re: Good Morrow peeps
Hi.
Welcome to the forum.
Of course you can use UVK on your forum. After all, it's free, isn't it?
I'll try to find some time to make more tutorials so you can just copy/paste the instructions to your forum.
Thanks for registering.
Essexboy
Post by Essexboy »
Hope you don't mind but I have made a few whilst I was playing
Please download UVK to your desktop and install
On the main screen select Scan and create log
Select the elements as shown on the left and click run scan
Please post the log generated
Run UVK and on the front screen select Run UVK scripts
Copy and then Paste the contents of the following code box into the blank box and select Run/Fix listed
Post the log on completion
Repairs
Run UVK and select Repair system then select the following tasks :
Run UVK and select Repair system then select More fixes
Run the following tasks
Select Automatic Malware scans
Select Repair script options
Tick the following items and reboot
Now that's a very nice job.
Way to do it! Keep up with the good work!
Edit: Some suggestions though:
On the automatic AntiMalware scans, instead of telling the user to reboot you can tell him to check Reboot computer after all done , unless you include the combofix scan.
It may also be a good idea to tell the user to host or post the contents of the logs created int the folder UVKAutoScansLogs on the desktop after the reboot.
user24
Post by user24 »
Hi guys i think its a great tool to use actually best i have found till now.
Essexboy
Post by Essexboy »
Cheers Fred I will add that - I did notice them when I was playing and thought must change that, and then promptly forgot :lol:
Nice to see you here Michael and welcome. :)
