[SOLVED] <IEStartPages> | Start Page | Google
Hello Fred,
Is it possible to make this script command (<IEStartPages> | Start Page | Google) editable to choose the search provider desired? Like Yahoo or Bing etc.
The new Bata 5.5.4.0 seems to be working well. The reboot in safe mode is nice and the new beep options are exactly what I needed. Thank you! :D
Re: <IEStartPages> | Start Page | Google
Hello, Bill.
The <IEStartPages> | Start Page | Google command does not change the search provider. It changes the Internet explorer's start page, which is the page that is opened when the user launches IE.
A search provider is the search engine used when the user types search keywords in the address bar.
Anyway, you can do most everything from a UVK script, you just need to know how to do it.
For instance, to change the start page to http://www.yahoo.com you just need a UVK script as follows:
<Reg>
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]
"Start Page"="http://www.yahoo.com/"
As for the search providers, it's a bit more complicated, but can be done too.
Search providers are saved int the following key:
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchScopes
Each search provider is saved in a subkey which has a GUID formated name like {7E9F85DD-DE48-4CFA-9257-CE61D9F63168}
The DefaultScope value tells which key corresponds to the default search provider.
Let me know if you need an example, and for which search provider you need the example.
Thank you Fred. I did actually mean the start page. That’s good information you gave me. I often forget to change the start page back to what someone was using and then get a call saying it’s different. Not a huge deal for most, but I live in a small town with many elderly people and it shakes them up when it’s changed. I’m going to create my scripts with the different start pages so I can just check what they are using and choose my script accordingly. Thanks again. :D
You're welcome, Bill. Anytime you have questions, just ask.
I'm marking the topic as solved.
