Beep on upon completion
Hello Fred,
Thanks for the updated version of UVK. Nice work. :D :idea: I’m wondering if in the next update you could add to the log analyzer script builder a command to beep on upon completion of an automated script to grab my attention so I would know when it’s done. That way I could do other stuff and when the beep is heard I could go back to do whatever else I need to without having to keep checking on it.
Re: Beep on upon completion
No prob. That's a good idea. Will make a new <Beep> command.
You will be able to define the number of times to beep. i.e: <Beep>3 will beep 3 times.
What do you think?
Being able to change the number of beeps is a great idea. One could maybe throw a certain number of beep in the script so you would have an idea of where it’s at along the way. Thanks Fred. :D
Done. I'll make a beta version available soon, so users can test.
I made it play the tada.wav file in %Windir%\Media. I thought it's nicer than a simple beep.
Thank you Fred. I like that. 8-) It will be very helpful.
Hi gilroy, welcome, and good luck with your IT learning.
Don't hesitate to ask if you need any help.
