[Solved]Disable Windows Defender?
netmonk99
Post by netmonk99 »
Is there a way to turn off / disable Windows Defender using a UVK script?
Thanks,
NM
Re: Disable Windows Defender?
Sure. You can do most anything with a UVK script.
All you have to do is stop the Windows defender service and then disable it:
 <CmdScript>
@echo off
sc.exe stop WinDefend
sc.exe config WinDefend start= disabled
To re-enable it you just have to enable the service and start it:
 <CmdScript>
@echo off
sc.exe config WinDefend start= delayed-auto
sc.exe start WinDefend
Have a nice sunday.
netmonk99
Post by netmonk99 »
Thanks, Fred. Works like a charm. You're the best!
