Visual Effects Optimization
Muhammad Tasneem
Post by Muhammad Tasneem »
Can you add Visual effect settings in "Tools and Tweaks"?
like we do in windows Control Panel > System & Security > System > Advanced system settings > Advanced (Tab) > Settings (In Performance)
Visual Effects.jpg (52.35 KiB) Viewed 23286 times
Additionally some pre-define settings:
For example:
-Best appearance.
-Best Performance.
-No Animation. (disable Option 1,2,3)
-No Animation + Fade. (disable Option 1,2,3,5,6,7)
-Custom 1
-Custom 2
Muhammad Tasneem
Re: Visual Effects Optimization
Version 10.10.0.0:
Nice Work Fred. It is good to see all icons in one place.
