Is is possible to use a UVK script to open a command prompt and paste a line of text into it, and then have the script press enter (run)?
Like so...
<UVKCommandsScript>
<RunSfcScan>
<CmdScript>
@echo off
findstr /c:”[SR]” %windir%\Logs\CBS\CBS.log >”%userprofile%\Desktop\sfcdetails.txt”
The above snippet should, of course, run SFC and then the line of text should paste the SFC results onto the desktop for easy finding/reading.
Any assistance would be greatly appreciated!
[Solved]Paste line of text into a command prompt and run it?
Re: Paste a line of text into a command prompt and run it?
Hi netmonk99.
Your code should work fine. However, when I tested it, it didn't work because the double quotes had been modified, probably by copy/paste in the forum.
For instance, the code should be:
But not:
Do you see the difference in the double quotes?
Just rewrite them in the script and it should be fine.
To debug the result of the cmd commands you can use <RunWait> and cmd /k. e.g.
Hope it helps.
<RunSfcScan>
<CmdScript>
@echo off
findstr /c:"[SR]" %windir%\Logs\CBS\CBS.log >"%userprofile%\Desktop\sfcdetails.txt"
<RunSfcScan>
<CmdScript>
@echo off
<RunWait>
cmd /k findstr /c:"[SR]" %windir%\Logs\CBS\CBS.log >"%userprofile%\Desktop\sfcdetails.txt"
Ohh, okay, I see the difference now. Thanks for pointing that out!
And thanks for making such an awesome program!
