Backup and Recovery Issue
Gunn
Post by Gunn »
I am running windows 10 with the latest updates and I am having a problem with Backup and Recovery getting it to work. The problem is once I create the backup job and go to run it it won't run. When I press Start backup
nothing happens. It works on other PCs, just not this particular PC. Any ideas!
Re: Backup and Recovery Issue
Hey Gunn.
Please ensure the backup folder name does not contain special characters. Also ensure the application has read/write access to the directory where the backup folder is to be created. When you press Save only, the backup folder should be automatically created. If it's not, then you have an access denied issue. If you're backing up to a flash drive, check out if it's not locked.
Gunn
Post by Gunn »
Yes, when I pressed save the folder was created. I also tried to a USB drive and got the same results. Seems to do that only on this one PC. Works everywhere else.
