System Repair order
Locked
MartijnH
System Repair order
Post by MartijnH »
Hello Fred,
I am trying to create a new system repair script using 'System Repair' in the tool.
Is there a way to change the fixed order of System Repair?
I would like to have some Maintenance actions like emptying folders done before I start my scans.
Hope there is a way to do what I want.
Martijn
Re: System Repair order
Hey Martijn.
Yes, you can add any items you want to run first to the "Top Apps and fixes" group. You can find that option in the right-click menu of a hilighted item.
Additionally, items in this group can also be moved up and down in the list. That will allow you to set the desired running order.
Locked
