Using “Reset IE and internet settings” ticks “Show tabs on separate row” in IE. UVK version 10.7.4.0
Re: Reset IE and internet settings
Thanks for the bug report, Bill. UVK just runs the rundll32 inetcpl.cpl ResetIEtoDefaults command. So I don't think I can change what the command does. I think the command does that because it is the default in IE. At least it is enabled in my IE, and I never used it before.
Thanks Fred. Not a bug at all. It never used to do that. Microsoft changed something because it’s doing it when it’s reset through IE now as well. I didn’t think to check that until you responded.
I’m getting sick of Microsoft. Every update turns step recorder back on. And what about the doing experiments on peoples machines setting. I don’t really know where that setting is but it’s a setting that can be disabled with DoNotSpy 10. I change a setting because I don’t like where it’s at and those asses set it back. It pisses me off.
I sometimes wish I had the balls to just cut the damn cord. Rant over.
