Once watermark is closed, stay closed
I've got the watermark set to run when I open UVK - lets me check the hours on the HD and its SMART right off.
Once I've got that info, I often close it but, when I go between sections (e.g. into SU) and then 'home' back to the main screen, it restarts. Could it not do that? If UVK ends up restarting during repairs, it's fine if it restarts with the program but, once closed in a session, I'd much prefer it to stay closed.
Re: Once watermark is closed, stay closed
Xander, I would describe this more as a bug. By your description, it seems Fred checks for the watermark in the opening of the main screen does not take into account you closed it. It should prolly offer the option to reopen as someone may have closed it for a specific task but actually wants it there generally. That's kind of a unique find, I wonder how many other people know it works that way?
Hi guys. Thanks for reporting this.
Yes, that's a bug. DW should be started only when the application launched, not every time we go to the home section. Will be fixed in the next update.
Thanks, Fred.
