Reports
Reports
I already posted about the RepairShopR seemly not working so I did more research and found that after closing the repair section, my professional report does not open in the browser either.
Are these two issues related?
Of note, the report IS created on the desktop BUT subsequent runs of the system repair creates a new repair file instead of appending to the current file. If this is correct action then I'm fine with it, I just thought I would point it out.
Re: Reports
Hey Jim.
Thanks for the bug report. I will check it out ASAP.
I don't know if the report not opening issue is related to RepairShopr, but I will try to figure it out.
Normally UVK appends to the current report until you exit the System repair section, but the same report should be used if the computer is rebooted before the current repair operation ends.
