The Scan button does not change from "Clean" when it's done cleaning.
Create restore point is no longer checked by default
Also, UAK says it will close browser windows but does not. Possibly related to this is that it does not remove everything it's supposed to.
Ealier today, on one computer I had UAK run for more than 10 hours with no end in sight.
UAK 5.1
UAK 5.1
Re: UAK 5.1
Hi, Jim.
The Scan button does not change until you cleanup all the items, which you probably never do. To do a new scan, press Menu and then select New scan.
I will make Create restore point be checked by default.
UAK does not close browser windows unless it needs to. i.e. it will not close Chrome unless there are items to cleanup in Chrome's tab.
Can you please tell what is it that UAK did not remove and was supposed to?
Can you please tell what UAK was doing when it ran for more than 10 hours? Scan? Repair?
Re: UAK 5.1
Scan in the malware section.
I don't remember right off the items it was supposed to clean.
