SR fixes description
I just notice that because I wanted to add some more fixes in my uvk sr settings file but In SR section, some fixes doesn't have the good description on the right pane (seems they are wrong only in top apps and fixes).
For example "Reset Ip, winsock and proxy" have the description that should be for "reset the host file and dns", the "reset the host file and dns" have the description that should be for "reset the dns settings".
"reboot the computer" says it will shutdown, "Optimize boot and shutdown" says it will defrag all drives, malwarebytes says it will launch UAK, well all is mixed up...
Re: SR fixes description
That's really weird. I think your SR file is corrupted. If you send it over to me through MP, I can get it fixed for you.
For everyone's information, this was actually caused by a bug, and not by corruption in Manu's SR file. I was able to reproduce it with the help of the SR file Manu sent me and I successfully fixed the bug.
Will be working properly after the next update.
Just noticed that it is also mixed in report.html file, don't know if your fix will also fix it there (I guess, since it's related) so I prefer to notice you about it.
