There is a known issue in Firefox since since WAY back when and they still refuse to fix it. On certain printers, if you use the paper size from another printer, that printer gets stuck with that paper size and you have to edit the settings to get it reset. As you know, Firefox has tons of settings.
Can you make an app to reset the printer settings in Firefox? preferably individually....
For example if I set the print size for my receipt printer with is 3.15 x12 for some reason and then I actually print with my Laser printer, it set the lasers paper size to my receipt printer size
Firefox
Firefox
Re: Firefox
Thanks for the request, Jim. I wasn't aware of this FF bug. I will make the fix available for the next update, if I figure out how to do it.
Re: Firefox
Fred, It's actually a pretty obscure bug. I would have to go hunt but it is documented and it only appears in very specific situations. However, it it happens to you, it could drive you nuts trying to figure it out. Guess it was a benefit to me that I'm already nuts
