Tech Licence and Portable version
sudo
Post by sudo »
I have a request and a question. First let me ask the question?
Is there a way to keep the UVK options from computer to computer. Such as protecting it with a password. The portable version is well not so portable if I have to keep installing -.- .
Also is there a way to brand my logo on the actual program icon when it installs?
Thanks, and keep up the good work. Love the program so far!
Re: Tech Licence and Portable version
HI Sudo, welcome to the forums.
Interesting question. Maybe I'll add a feature to save the settings to an ini file in the future. For now, you must do it manually. There is obviously ways to take the settings from a pc to another, since they are saved to the registry, but the running protection password is saved in a secret key, which is deleted when UVK is uninstalled, or the password is disabled.
I don't think I should tell which key it is. It would allow to disable the password without using UVK, and you wouldn't want that, would you? :)
Not yet. To make that feature available, I would have to make UVK create the new icon, or have users to upload it when buying the key. let's see if I can come up with an easy way.
sudo
Post by sudo »
That would be awesome! Anyway keep up the good work!
