I didn't find the Load/save/save and Apply setting button in System Immunization. (but I found the save/save and apply button in Execute Prevent) did I miss something or it is not present there.
It is really good if the these option are available.
Thanks in advance
Save/Load System Immunization settings
Re: Save/Load System Immunization settings
lol - I believe this button is for apply not for saving or load settings.
I want to save settings (selected Immunization) for applying on other computer. I want to make different settings for different senerio like db operator PC, Executive's PC, gaming PC etc
Well, that’s a horse of a different color. I believe that would be saved in the registry. I’m not so sure what the best way to do that would be. I think Fred will chime in eventually.
Hey guys.
There is no such feature, at least for now. You can easily select the recommended areas, or all, or none, by clicking the corresponding link at the bottom of the window.
Save/load already available in most sections. It is good if it will be add in future.
