[Solved] Reports - a multiple files into a single file
TheLaptopFixers
Post by TheLaptopFixers »
Hi there,
I run UVK to automate a complete PC service. When the machine reboots, a second report or third report is generate leaving several reports on the desktop. Is there a way to prevent this and merge everything into a single report?
Paul
Re: Reports - a multiple files into a single file
It should create a single report for each repair operation, even if the PC reboots. I'll check that out. Thanks for reporting.
