Automatically run UVK
I'm playing around and learning. I have found -auto will run most things in my script without any interaction from the user. Some of the things show up on the screen however. Is there a -silent command I could use to stop that from happening?
Re: Automatically run UVK
I noticed in your Huskyclean script that only the reports show up. They do go away on their own but it would be good if they didn't show at all.
Hi guys.
Can you please tell exactly what shows up?
The Reports dialog shows up while it's sending the report then goes away when it's done. So, it is automatic but it's not hidden.
I have a task scheduled that runs UVK and then does a -readfile "HuskyClean.uvk" -auto. When I do that everything is runs in the background except a couple things.
1. When it's cleaning the Internet Explorer browser, I see the little box that shows it's cleaning (no big deal).
2. When the "Send Reports" part happens, it opens UVK to the reporting screen. When the reports are generated and sent, it closes.
FredJClaus, the IE cleanup dialogs showing up is controled by the system, can't be changed.
As for sending the reports silently, try replacingwith
That should do the trick.
<SendReports>
<RunWait>
%UVKExe% -SendReports -Auto
Well the good news is I didn't get the reporting part on the screen when I did a test run of the script. Bad news is I didn't get a report in my email. Did I do something wrong here?
<UVKCommandsScript>
<CreateRestorePoint>
<ResetGroupPolicy>
<ResetNumLockOn>
<ResetPrintSpool>
<ResetCDBurnQueue>
<ResetWLAN>
<CleanAllUsersTemp>
<EmptyBrowsersCache>
<DeleteBrowsersCookies>
<ClearIEHistory>
<ClearEventLogs>
<ClearErrorReports>
<ClearShellCache>
<CleanMSIOrphanFiles>
<CleanupRegistry>
<CleanupJunkFiles>
<RunWait>
<UVKCommandsScript>
<ResetGroupPolicy>
<ResetNumLockOn>
<ResetPrintSpool>
<ResetCDBurnQueue>
<ResetWLAN>
<CleanAllUsersTemp>
<ClearIEHistory>
<ClearEventLogs>
<ClearErrorReports>
<ClearShellCache>
<CleanupRegistry>
<CleanupJunkFiles>
<RunWait>
Add your ftp info
That was it Jim. I didn't set up in the UVK reporting section how I wanted to report and where to send it.
Glad that sorted it out for now, guys. I will make <SendReports> work properly in the next update.
