PeaZip Portable
wrc559
PeaZip Portable
Post by wrc559 »
Few apps won't download, including PeaZip Portable.
Not sure if there is just a coding error.
Thanks fred.
Re: PeaZip Portable
Hey WRC. I just tested peazip and it's working fine for me. Sometimes tools don't download because the server they download from is temporarily offline. In this case you should try again later.
Also check if you're running the latest TTS version (3.1) and the latest database (36).
