Cortona error
FredJClaus
Cortona error
Post by FredJClaus »
If you use the "Kill all non critical processes" function Cortona is stopped in Windows 10. This causes a big glitch and reboots Windows.
Re: Cortona error
Interesting.....
Re: Cortona error
I tested this issue and it's confirmed. You should use Kill all non system processes, or one of the remaining options instead. The issue does not need a reboot, though. You can keep working on the computer, and a simple logoff/logon brings Cortana back.
Thanks for reporting. I'm not sure if I'm going to take any action related to this issue. The Kill all non critical processes feature is supposed to kill all the processes that can be killed without making the computer reboot. Obviously programs like cortana are affected, but the PC does not reboot, so it's acting as it should. You can add the cortana's process to the ignored processes list.
FredJClaus
Re: Cortona error
Thanks for the clarification Fred.
