script uak
csm
script uak
Post by csm »
purchased uvk today. I am trying to let UAk remove the detected threats automatically.
I can't get it to work, uak starts , scans and display the results, but i can't manage to hit the ok button. Tried wiht the options "visible" and "enable", nothing seems to work.
can anyone please helpme with this?
example script
<UVKCommandsScript>
<UAKScan>
<Run>
->WaitWindow() ; wait for the scan report
;->WaitControlState([CLASS:Button; INSTANCE:1, Enabled); hit the ok button
->WaitControlState([CLASS:Button; INSTANCE:1], Visible); hit the ok button
->ClickControl([CLASS:Button; INSTANCE:1])
Re: script uak
Hi csm, welcome.
Your script is not working because <UAKScan> waits until the UAK scan ends, before stepping to the next commands, so when your commands are sent, UAK is already closed.
You can achieve similar effect using the standalone version of UAK. Here's a script I built quickly, it may need some adjustments.
<UpdateSoftware> -x86
%ThirdParty%\UAK.exe | http://www.carifred.com/ultra_adware_killer/UltraAdwareKiller.exe
<UpdateSoftware> -x64
%ThirdParty%\UAK.exe | http://www.carifred.com/ultra_adware_killer/UltraAdwareKiller64.exe
<Run>
%ThirdParty%\UAK.exe /scan /noupdate
->WaitWindow()
->WaitWindow()
->CloseWindow()
->ClickControl([CLASS:Static; INSTANCE:15], 1)
->WaitWindow()
->ClickWindowPos(93, 158)
->WaitWindowClose(3)
->WaitWindow()
->WaitWindowClose(4)
->WaitWindow()
->ClickWindowPos(311, 127)
->CloseWindow(1)
->WaitProcessClose()
csm
Re: script uak
Post by csm »
Thanks Fred, that worked!
I am now using d7II's to send the report to PCRT. I am planning to use UVK to clean up my customers computers. UVk has a FTP function to send the reports. It is working fine, but i have to put in the credentials on every new computer ii scan. I am running UVK from my nas.
Do i need to configure something?
Thanks,
Will
Re: script uak
csm, you can save your FTP credentials to an INI file, which is automatically loaded by the UVK packages,
http://www.carifred.com/uvk/help/load_settings.php
http://www.carifred.com/uvk/help/report ... e_settings
Let's see if Manu, Jim, or Xander will chime in to help you more with the PCRT integration.
Re: script uak
Hi csm,
To view/attach uvk reports in pcrt you just have to save your ftp credentials like Fred said and that's it.
However if you want to be able to import system specs like with d7 you'll have to wait for luke to add the feature in pcrt or apply this mod by yourself => viewtopic.php?f=9&t=1230#p5204
Re: script uak
CSM
The only thing I can add to this, keep in mind PCRT has a bug in it that makes it not recognize some legal file names. For example, if the user name is "Charger 440" PCRT will not recognize it but if it is "Charger440" it will work just fine.
We have talked about this and I am guessing that other dude strips the spaces out but Fred said he wasn't going to because he wanted to keep name as it appears on the machine. I stand by Fred on that because they are both legal file names and PCRT should work with each one interchangeably.
Re: script uak
Jim, the latest beta took care of that issue. It auto-replaces non-supported characters with underscores.
Re: script uak
Have you officially released said beta or is it part of the c++ rewrite?
