TTS wont accept password
wrc559
Post by wrc559 »
Bug Report for TTS.
I deleted the TTSLicense, TTs_Tools, TTS_Settings.dat files and redownloaded the TTS program and reactivated the license to try and solve the issue. However I tick the Password Protect box and add the password, press Save. When I go back to check the settings the tick box has been unticked.
I tried absolutely everything even a new setup and it still did not solve the issue.
Anyone else had similar or is this a new issue :S
Can upload a video of it happening if you wish?
Re: TTS wont accept password
wrc, bug is confirmed. No idea of what happened. The last time I tried it was working fine. Thanks for reporting, and sorry for the inconvenient. I'll fix this ASAP.
