What is the trick to uninstalling wit MSI strings
wrc559
Post by wrc559 »
Hey,
So I noticed a lot of programs these days have uninstallation strings and not uninstall.exe files.
How do you go about uninstalling these programs using TTS ?
IE: ITunes uninstall location is MsiExec.exe /I{9E9CFD9F-64D6-498F-8584-E5CD08BA60BE}
However, This uninstall location changes on every PC, so you simply can't use this location for TTS uninstallation settings.
Is there a trick to this I am missing :(?
Thanks as always!!!
wrc559
Re: What is the trick to uninstalling wit MSI strings
Post by wrc559 »
I assume this would be ittt ???
%SystemRoot%\Installer\1105b6.msi
If this is the same for you please let me know. :)
In this case you can use the install package for both install and uninstall.
Examples of install commands:
%ToolsDir%\ProductPackage.msi /passive /norestart
msiexec.exe /i "%ToolsDir%\ProductPackage.msi" /passive /norestart
Examples of uninstall commands:
msiexec.exe /uninstall "%ToolsDir%\ProductPackage.msi" /passive /norestart
msiexec.exe /x "%ToolsDir%\ProductPackage.msi" /passive /norestart
If the product code changes at every install, this is the best option IMHO. But you need to download the package even if you just want to uninstall.
For more Windows installer command line switches run the following command:
msiexec.exe /?
wrc559
Post by wrc559 »
This is my uninstallation string from HTC Sync Manager
Installation:http://dl4.htc.com/download/htc-sync-ma ... .0_htc.exe
UVK Uninstall string: MsiExec.exe /X{231D0C79-98A6-4693-A366-36DE7D7346EC}
UVK Uninstall file: C:\Windows\Installer\1105ce.msi
I tried to follow your above commands
Uninstall string: msiexec.exe /uninstall "%SystemRoot%\Installer\1105ce.msi" /passive /norestart msiexec.exe /x "%SystemRoot%\Installer\1105ce.msi" /passive /norestart
Hmm keep coming up with the windows installer log displaying the command lines.
Have I done this wrong?
Hum, those commands should run fine. Can you please post the commands in a code tag? I can't ensure they don't have a leading or trailing white spaces.
Also if you canpost a screenshot with the error message, it may help to figure out what's wrong.
wrc559
Post by wrc559 »
HTC Sync specific
HTC Sync specific
HTC SYNC.png (612.86 KiB) Viewed 37907 times
WRC, no wonder it doesn't work. You entered both commands in the same command. You need to use either
OR
Not both. Copy one of the commands above and paste it in the TTS uninstall command field, ensuring the command does not have any leading or trailing white space.
wrc559
Post by wrc559 »
Fred wrote:WRC, no wonder it doesn't work. You entered both commands in the same command. You need to use either
OR
ahhhhhhhhh!!!!.... hehe...
Well Thank you! hope this helps other people :)
Thanks fred!
wrc559
Post by wrc559 »
Ahh, Upon testing this is a pointless procedure for software such as iTunes, Samsung Smart Switch and other mobile device backup systems.
The MSI software package when installed changes names each time it is installed, so continuous updating would be required, which is what I believe you touched on previously. :(
That's why I mentioned using the install packages for both install and uninstall. If the downloaded package is an MSI package, it is straight forward. If the MSI package is compressed in an exe, usually the exe passes the command line switches to msiexec.
So this should work:
Download URL:
http://dl4.htc.com/download/htc-sync-manager/setup_3.1.46.0_htc.exe
Download file:
%ToolsDir%\HTCSetup.exe
Install command:
%ToolsDir%\HTCSetup.exe /passive /norestart
Uninstall command
%ToolsDir%\HTCSetup.exe /x /passive /norestart
