Open Office TTS
wrc559
Open Office TTS
Post by wrc559 »
Sorry about my silliness.
I am trying to get OpenOffice to perform an automatic install.
I tried pasting this as one of the commands in TTS.
start /wait msiexec /qn /norestart /i openofficeorg23.msi
Also a modified version.
%ToolsDir%\OpenOffice /norestart /qn /i
but couldn't get my head around it.
Sorry!!!
Re: Open Office TTS
WRC, the best way to insert the path of the files to run is to use the Browse button, or simply drag the file to execute to the text input. Then you just need to append the extra parameters.
Looking at the commands you posted, it seem like you need this:
%ToolsDir%\OpenOffice\openofficeorg23.msi /quiet /norestart
You can use the /passive switch instead of /quiet, which will show only progress info:
%ToolsDir%\OpenOffice\openofficeorg23.msi /passive /norestart
wrc559
Re: Open Office TTS
Post by wrc559 »
Thanks Fred, Appreciate your response.
