Fred, do you want logs of what UAK isn't catching?
Would that be helpful? The laptop I've got here had a bunch of stuff and UAK caught a good handful but I'm just running MBAM now and it's just hit 202 items so far. Would us sending you the scan logs of MBAM/ADW/etc be of any use to you?
Edit: I don't mean to sound like some kind of dig against UAK. It's great; just thinking there might be ways we can help improve it.
Re: Fred, do you want logs of what UAK isn't catching?
Xander,
I asked that same question but I don't recall the answer to it. Will have to go back and look.
Morning guys.
Yes, please send me logs of whatever UAK does not find. You can send them by PM if you don't wnat to make those logs publicly available.
Fred wrote:Yes, please send me logs of whatever UAK does not find.
With this in mind, could I suggest that, in the SR section, that UAK be bumped to the top of the list of built-in scanners? This way, the scans that follow will be finding only things that were not caught and you'd have less duplication and filtering to do.
Hi Xander.
OK, I'll do that for the next update.
