Third Party App
MCD IT
Third Party App
Post by MCD IT »
Hello,
I am currently trying to get Crystaldiskinfo to work as a third party app. I am using the majorgeeks page and the download works well. As it is a zip file, it is automatically unzipped into a folder of the same name. The only problem I am having is that I can't quite get it to run! Inside the "Crystaldiskinfo" folder there are two .exe files for 32 & 64. I have set these the regular way, but I can't seem to get it. Is there anything obvious I am doing wrong?
Re: Third Party App
Hi MCD IT.
Leave the first command empty and delete the white space in %ThirdParty%, in the commands 2 and three.
MCD IT
Re: Third Party App
Post by MCD IT »
Doh! It had to be something simple!
It's now working like a charm. Thanks again!
Re: Third Party App
No prob MDC.
Keep up the good work!
