Launch Scans Concurrently
I often run scans from two or three or more programs simultaneously. Does the program have this feature? If not I highly recommend it be added.
Re: Launch Scans Concurrently
Hi mswarbrick.
The next UVK version will allow you to simultaneously run several instances of UVK. That should fit your needs.
You can also perform simultaneous scans if you create third party apps that run UVK scripts. More info in the following topics:
viewtopic.php?f=1&t=997&p=2819
viewtopic.php?f=1&p=2922#p2922
