[SOLVED]Error: Array variable ..
Re: Error: Array variable ..
Yes!!! I found it! thank you so much for helping me out with this one, George.
it was really an error code. Sorry I said it was only for your pc. In fact, it would happen for all machines with more processors than network adapters.
Caused by copy/paste. My bad...
Here's the new file. This one should work fine, I'm sure.
Advice for anyone else downloading this file: It's only for 32 bit systems, don't use for x64!
I'll try to find more bugs, and update a new build today. Thanks again.
Aaaa.. It's GOOD! Bingo! You know what you doing. You are on the way to victory!
And we have Bios, Bios date etc.! Thank you! But no LAN/WAN here ..
So soon the major version of UVK. Yours Pro version.
Glad to have been able to help, Fred.
W.XPSP2, 13proc., 17serv.; IE8 sandboxed (and tweaked: NO downloads, plugins ..). I'm on MalwareTips.com forums somewhere, sorry ..
Well, you have a modem, not a lan or wan adapter...
But keep following this topic. I'll see what I can do, but will need you to test. I don't have any machine with modem here, at the moment.
No problem, I'm at your disposal.
I'm proud that I can do something for so exceptional product, your UVK - killer app.
Thanks George, I really appreciate your help.
Here's another file. I disabled all the filters for the network interfaces. It should now show them all. But I don't want it to show them all, just Lan, Wan, and modem adapters.
So the file will create a new log in your desktop. I need you to post the log's text and tell me which interface in the log corresponds to your modem, OK?
- UVK_en.zip
- (763.23 KiB) Downloaded 713 times
Fred, check yor PM, please.
PS. It's better with my PM, in Outbox I have my last message, to you. After restart of my PC.
Hi George, I had to go out for a few hours. Please check your PM.
OK., no problem!
Ok here's the new exe. I hope it's the last one in this topic.
It should show your Local area network now.
- UVK_en.zip
- (763.26 KiB) Downloaded 724 times
OK., I posted PM for you ..
So everything is fine now, time to compile and release.
Thanks again for your precious help, George from MalwareTips.
