System Info
Re: System Info
Thomas, you need to install the full package and replace only UVK_en64.exe, in the Installation folder, with this one.
thomass
Re: System Info
Post by thomass »
Ok Fred, works great.
Thank you.
thomass
Re: System Info
Post by thomass »
As you can see from the image, the issue is back.
Re: System Info
Thomas, I will release a beta version soon, where you can try it out more properly.
thomass
Re: System Info
Post by thomass »
Thank you Fred.
Just tried the latest build, 10.7.7.1 works well.
Re: System Info
Great to know, Thomas. Thanks for your cooperation.
