Report ID in filename
Re: Report ID in filename
Thanks for fixing underscore issue, It now works fine !! :)
I don't know if you've seen some post above, another request related with this one:
As a side note, now that the ID is in the filename, could we have a way to set a report id via command line?
So we can specify a report id when using -SendReports
I remember I read that, but I forgot to implement it. Sorry about that. I will add it for the next update.
