Power settings
Power settings
There was a request at one point (might have even been me that requested it, not sure) for power settings. After quite a bit of searching I finally found a way to do it.
This script sets the lid close to do nothing and Sleep, screen time and hard drive to never. The screen dim is set to 20 minutes. If you want to reset to close to default settings just run it again and select NO when it asks you if you want to use Tech settings.
It does need a lil work but Fred may add it before I get to fine tune it, if not, I will continue to work on it and fine tune it.
PowerSettings.uvk
Power settings tool
(2.55 KiB) Downloaded 679 times
Re: Power settings
Nice, but it can be easily done the right way: Using the Windows API.
You'd just need a few functions:
PowerGetActiveScheme to get the active power scheme.
LocalFree to free up the returned GUID pointer.
PowerWriteACValueIndex to set those values.
PowerSetActiveScheme to apply the changes.
UuidFromString so you don't have to hard code the GUIDs yourself.
That may be a good learning curve, if you're really interested in learning AutoIt, but I can give you a hand. Let me know.
Re: Power settings
That's part of what took so long for me too do it. I was looking for an api or I figured the .net framework would do it. I seen these apis but was not sure if they would work and didn't find anything in. Net but there has to be something in there somewhere.
Re: Power settings
Well, those APIs do exactly the same thing you did with your script. The code is pretty easy. Here it goes:
 <AutoItScript>
Global Const $tagGUID = 'ULONG Data1;USHORT Data2;USHORT Data3;BYTE Data4[8]'
_SetOptimalPowerSettings()
Func _SetOptimalPowerSettings()
	Local $ret = 0, $PowerID  = _PowerGetActiveScheme()
	If $PowerID  = 0 Then
		MsgBox(0,'Error','The active scheme could not be retrieved.')
		Exit 1
	EndIf
	;Find out if we are turning off or on
	Local $Qresponse = MsgBox(4,"Technician Settings", _
	"Do you want to turn on Technician optimal power settings?")
	;Lid Close
	Local $value = ($QResponse = 6) ? 0 : 1
	$ret += _PowerWriteACValueIndex($PowerID, _
	_UuidFromString('4f971e89-eebd-4455-a8de-9e59040e7347'), _
	_UuidFromString('5ca83367-6e45-459f-a27b-476b1d01c936'), $value)
	$ret += _PowerWriteACValueIndex( _
	_UuidFromString('381b4222-f694-41f0-9685-ff5bb260df2e'), _
	;HD
	$value = ($QResponse = 6) ? 0 : 1800
	_UuidFromString('0012ee47-9041-4b5d-9b77-535fba8b1442'), _
	_UuidFromString('6738e2c4-e8a5-4a42-b16a-e040e769756e'), $value)
	;Sleep Time out
	_UuidFromString('238c9fa8-0aad-41ed-83f4-97be242c8f20'), _
	_UuidFromString('29f6c1db-86da-48c5-9fdb-f2b67b1f44da'), $value)
	;Dim Display
	$value = ($QResponse = 6) ? 900 : 300
	_UuidFromString('7516b95f-f776-4464-8c53-06167f40cc99'), _
	_UuidFromString('17aaa29b-8b43-4b94-aafe-35f64daaf1ee'), $value)
	;Turn off display
	$value = ($QResponse = 6) ? 0 : 1200
	_UuidFromString('3c0bc021-c8a8-4e07-a973-6b14cbcb2b7e'), $value)
	;Apply changes
	Local $msg = _PowerSetActiveScheme($PowerID) ? _
	'The technician optimal power settings were successfully applied.' : _
	'The technician optimal power settings could not be applied.'
	;Free the pointer
	_LocalFree($PowerID )
	MsgBox(0,'Technician Settings',$msg&@CRLF&@CRLF&$ret&' power policies applied.')
EndFunc ;==> _SetOptimalPowerSettings
Func _PowerGetActiveScheme()
	Local $aCall = DllCall('PowrProf.dll', 'DWORD','PowerGetActiveScheme', 'ptr',0, 'ptr*',0)
	If @error Or $aCall[0] Then Return SetError(1,0,0)
	Return $aCall[2]
EndFunc ;==> _PowerGetActiveScheme
Func _LocalFree($hmem)
	Local $aCall = DllCall('Kernel32.dll', 'ptr','LocalFree', 'ptr',$hmem)
	If Not @error Then Return Number($aCall[0] = 0)
EndFunc ;==> _LocalFree
Func _PowerWriteACValueIndex($SchemeGuid, $SubGroupGuid, $SettingGuid, $AcValueIndex)
	Local $pSchemeGuid = IsDllStruct($SchemeGuid) ? DllStructGetPtr($SchemeGuid) : $SchemeGuid
	Local $pSubGroupGuid = IsDllStruct($SubGroupGuid) ? DllStructGetPtr($SubGroupGuid) : $SubGroupGuid
	Local $pSettingGuid = IsDllStruct($SettingGuid) ? DllStructGetPtr($SettingGuid) : $SettingGuid
	Local $aCall = DllCall('PowrProf.dll', 'DWORD','PowerWriteACValueIndex', _
	'ptr',0, 'ptr',$pSchemeGuid, 'ptr',$pSubGroupGuid , 'ptr',$pSettingGuid, 'DWORD',$AcValueIndex)
EndFunc ;==> _PowerWriteACValueIndex
Func _PowerSetActiveScheme($SchemeGuid)
	Local $aCall = DllCall('PowrProf.dll', 'DWORD', 'PowerSetActiveScheme', 'ptr',0, 'ptr',$pSchemeGuid)
EndFunc ;==> _PowerSetActiveScheme
Func _UuidFromString($guidStr)
	Local $sret = DllStructCreate($tagGUID)
	Local $aCall = DllCall('Rpcrt4.dll', 'DWORD','UuidFromStringW', 'wstr',$guidStr, 'struct*',$sret)
	If @error Or $aCall[0] Then Return SetError(1,0,$sret)
	Return $sret
EndFunc ;==> _UuidFromString
Hope this helps you to get started using the Windows API from AutoIt. It allows you to do everything any other application does.
EDIT: Fixed a typo in the _LocalFree() function.
