Hey, im having issues with this command, This is my current script.
<UVKCommandsScript>
<Comment>
Download & install **** USB software
<UpdateSoftware> -x86
%ThirdParty%\tucmw32.zip | http://www.******.com.au/broadband/download/document/tucmw32-3.17.30227.zip
<UpdateSoftware> -x64
<UnzipFile>
%ThirdParty%\tucmw32.zip | %ThirdParty%\tucmw32
<RunWait>
However the unzip function just does nothing, any support is awesome!
UNZIP Command
Re: UNZIP Command
Hi wrc559.
Thanks for posting this, because it helped me to find a bug in the previous beta: The license key was not being installed by double-click.
On the other hand, the <UnzipFile> command is working fine for me. Please note that this command is only available to users having a valid UVK license.
Here's how I tested it:
I put a zip file in the %ThirdParty% folder named UAKdb.zip.
I create a script with the following code:
I run the script and got the following result:
I check if the zip file was extracted, and it did.
I'm not sure what may be your issue, my guess is, either the downloaded zip file is corrupt (i.e. bad download url), or your license is not installed when you run the script.
<UnzipFile>
%ThirdParty%\UAKdb.zip | %ThirdParty%\zip test
2015/03/25 10:21:50 Extracting %ThirdParty%\UAKdb.zip to %ThirdParty%\zip test...
The zip file was successfully extracted.
