Did some searching for this, but did not find anything.
I know the basics are covered in the Win 7/8/10 interface, but it would be helpful to have some user account options built-in to UVK. For example:
- Disable User
- Delete User
- Hide user from Login Screen**
- Create a User
- Remove password
- Auto-Login Control for a particular user
There are some other repair utilities that do this, but none do it great.
It seems that this is the the most common reason I leave UVK and start another tool when I am cleaning, updating, etc. a PC with UVK.
(appreciate the opportunity to post a request)
Simple User Account Manager
Re: Simple User Account Manager
Hi mavengroup, welcome.
A user manager would be a great addition to UVK. Will have to decide where to put it. Maybe the best thing to do is add a new section for the effect. I scheduled this for a future update.
Thanks for the suggestion.
Welcome mavengroup, it’s nice to have more users on the forums.
Thanks Fred, This will be a welcomed addition.
Fred wrote:Hi mavengroup, welcome.
Thanks for the welcome (from both of you). I am getting more and more into UVK as I add it to my toolkit. Sorry for the late reply (as I had forgot to check the notification). I am excited to see this possible addition in future releases. Thanks again.
Hi mavengroup. It is already present in UVK beta.
http://www.carifred.com/uvk/beta
http://www.carifred.com/uvk/help/quick_user_manager.php
This is sweet! Thanks!Fred wrote:Hi mavengroup. It is already present in UVK beta.
Any estimate when this version will be out of beta?
I'm not going to add any more features. I'l just debug it for a few days more, to ensure everything is working properly. It should be ready in a few days.
