If there is a way to just run a script I have not found it and if so could you point it out? What I mean is. when I create a script that I would like to add to my 3rd party apps I have to add it as command line option to UVK it's self which runs another instance of UVK. Can you make it so the existing instance would just run the script? That way they could run like any other 3rd party app.
Let me know what you think.
I still intend to comment on your power scheme script, I have just been busy.
Scripts
Scripts
Re: Scripts
Hi Jim. It is well documented. In fact each app can run up to four UVK scripts.
http://www.carifred.com/uvk/help/cmdswitches.php
http://www.carifred.com/uvk/help/custom ... _variables
Examples:
Note the paths are enclosed with double quotes. This a very good practice, if you want to ensure the success of your command.
Examples:
"%UVKExe%" -ReadFile "%InstallSourceDir%\myscript.uvk" -Auto
"%UVKExe%" -ReadFile "%Desktop%\myscript.uvk" -Auto
